Ashour
Mar 26, 2023Aspirant
Cannot connect ps5
my PS5 can detect the wifi but not connect to it any one can help?
microchip8
Mar 26, 2023Master
No.. not unless you provide really basic info
which router model?
which frimware version?
which band are you trying to connect the PS5? 2.4 or 5/6 GHz?
which router model?
- AshourMar 26, 2023Aspirant
I'm sorry I'm not an expert in this
- Nighthawk Wi-Fi 5 AC
- V1.2.8.40
- I'm trying to connect to 2.4
I'm using smart connect (2.4 5.6) I'm not sure if thats wise or not
I did reset the router but still issue happens
everything else connects fine
(PS5 is not on my blocked list)
if I use another router ps5 connects just fine
- microchip8Mar 26, 2023MasterNighthawk WiFi 5 AC is not a model, it's a WiFi class. Look at the label of your device, most likely it starts as Rxxxx (eg, R7000, R7800, etc)
First thing I'd try is disable Smart connect and name your 2 bands (SSIDs) differently, then try again and report.- AshourMar 26, 2023Aspirant
RAX120
I did turn off smart connect but still same things
