Ashour
Mar 26, 2023Aspirant
Cannot connect ps5
my PS5 can detect the wifi but not connect to it any one can help?
microchip8
Mar 26, 2023Master
Nighthawk WiFi 5 AC is not a model, it's a WiFi class. Look at the label of your device, most likely it starts as Rxxxx (eg, R7000, R7800, etc)
First thing I'd try is disable Smart connect and name your 2 bands (SSIDs) differently, then try again and report.
Ashour
RAX120
I did turn off smart connect but still same things
- FURRYe38Mar 26, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Check to see if the game console connects via ethernet LAN cable. CAT6 is recommended.
Maybe something to contact Sony support about for additional help and information regarding there product.
- microchip8Mar 26, 2023MasterYou can try disabling the AX feature. It sometimes can interfere with some devices, though it shouldn't, but worth a try.
And a RAX120 router is WiFi-6 (AX), not 5 (AC) đ
