JamieJammer
Aug 31, 2022Aspirant
Cannot connect to WIFI Nighthawk AX$ AX3000 4
Hi Just come back from holiday and cannot connect to WIFI. Device see it, but will not connect. I cannot check if there has been a firmware up date either Any ideas
Aug 31, 2022Guru - Experienced User
What error are you getting when you try to connect?
Does it connect and say "connected, no internet"?
Does it not see the wifi broadcasting at all?
Does it see the wifi but not able to connect?
What modem is the router connected to?
What actual router is it? AX3000 is a speed, not a model.
Did you try factory resetting the router?
- JamieJammerAug 31, 2022Aspirant
Hi
It is a NightHAWK AX4 AX3000- Model RAX40
You can see the router on phone but will not connect
Connected to Ethernet cable. Connected cable to my PC and worked fine
Tried factory reset with no success
- michaelkenwardSep 01, 2022Guru - Experienced User
You didn't answer the question from plemans about the modem/gateway. What is it?
The first thing to try, even before going anywhere near the nuclear option of a reset, is to restart the network.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
This can unscramble the router's brain and get it to behave itself.
- JamieJammerSep 01, 2022Aspirant
Hi
That did not work., It now says cannot get IP address when i try to connect with my phone
The modem/gataway is a virgin media one. Hub 4 /TG3492LG- VMB CM MAC ACF8CC80CA06
Any other suggestions?
