JamieJammer
Aug 31, 2022Aspirant
Cannot connect to WIFI Nighthawk AX$ AX3000 4
Hi Just come back from holiday and cannot connect to WIFI. Device see it, but will not connect. I cannot check if there has been a firmware up date either Any ideas
JamieJammer
Hi
It is a NightHAWK AX4 AX3000- Model RAX40
You can see the router on phone but will not connect
Connected to Ethernet cable. Connected cable to my PC and worked fine
Tried factory reset with no success
michaelkenward
Sep 01, 2022Guru - Experienced User
You didn't answer the question from plemans about the modem/gateway. What is it?
The first thing to try, even before going anywhere near the nuclear option of a reset, is to restart the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
This can unscramble the router's brain and get it to behave itself.
- JamieJammerSep 01, 2022Aspirant
Hi
That did not work., It now says cannot get IP address when i try to connect with my phone
The modem/gataway is a virgin media one. Hub 4 /TG3492LG- VMB CM MAC ACF8CC80CA06
Any other suggestions?
- michaelkenwardSep 01, 2022Guru - Experienced User
That will be a modem/router. So you are piling router on router. A bad idea:
What is Double NAT? | Answer | NETGEAR Supportand
How to fix issues with Double NAT | Answer | NETGEAR Support
When you set up the RAX40, it will have tried to avoid any conflicts. Sadly, it doesn't always stick. Maybe something rebooted itself in your absence and screwed up the settings.
The preferred fix is to put the Virgin box into bridge (modem only) mode:
virgin media one. hub 4 bridge mode - Google Search
At least Virgin, unlike BT, does not block this mode.
