quite68's avatar
quite68
Cannot disable beamforming on RAXE500 (fw V1.0.12.96_2.0.45)
In some situations (not sure which ones) I cannot disable beamforming. I uncheck the checkbox and press Apply but after settings are applied the checkbox is checked again. Any idea what is going on?...
  • quite68's avatar
    quite68
    Sep 28, 2023
    I suspect this is a bug in 1.0.12. I've reverted to 1.0.11 and it's working again.
