quite68
Sep 20, 2023Aspirant
Cannot disable beamforming on RAXE500 (fw V1.0.12.96_2.0.45)
In some situations (not sure which ones) I cannot disable beamforming. I uncheck the checkbox and press Apply but after settings are applied the checkbox is checked again. Any idea what is going on?...
- Sep 28, 2023
I suspect this is a bug in 1.0.12. I've reverted to 1.0.11 and it's working again.
mnhim001
Aug 06, 2024Aspirant
I am using Firmware Version V1.0.12.96_2.0.45 and can't uncheck "Enable Implicit Beamforming" either. I uncheck it and save the settings, after the settings update it comes back as checked.
I also have unchecked "Enable AX mode" to see if that would help, but still does not uncheck the "Enable Implicit Beamforming" after saving the settings.
This is frustrating, my Internet keeps dropping. All my hardwired devices stay connected while my wireless devices loses Internet (even though network settings shows its connected). I have to restart the router, every morning to give it a fresh start. I shouldn't have to do this, and troubleshooting doesn't help when the settings I am trying to apply doesn't stick.
- FURRYe38Aug 06, 2024Guru - Experienced User
Wondering if you reverted FW back to v1.0.0.48, does this change the behavior?
- mnhim001Aug 06, 2024Aspirant
If I revert back to older versions, do I need to reconfigure my VPN and setup my VPN clients all over again? That is the only reason holding me back from going down versions.
Would need to factory reset and setup from scratch. So I presume yes.
Might make a current back up configuration to file and mark it for v.96 version of FW. Then downgrade and FR and just check the setting. Most FW updates or downgrades, you'll need to most likely reconfigure VPN since I presume that possible security keys may change in between FW versions.
