roger1955
Nov 28, 2020Apprentice
Cannot enable Anywhere Access on Nighthawk App V2.7.0.27
Hello, When moving slider to enable Anywhere Accesson the Nighthawk app; "SOME ERROR OCCURRED WHILE ENABLING ANYWHERE ACCESS" POPS All boxes are checked in the router's GUI..... rebooted the rout...
- Dec 27, 2020
I just installed the latest firmware(V1.0.3.106_1.0.58) .......Anywhere Access still did not work. Since I usually do a factory reset upon completion of a firmware update, I did so. I can now enable Anywhere Access.
roger1955
Dec 04, 2020Apprentice
V1.0.3.102_1.0.56
roger1955
Screenshot also
- Christian_RDec 08, 2020NETGEAR Employee Retired
Hi roger1955,
Thanks for confirming. May you factory reset your router and run through the setup assistant again and also setup anywhere access.Thanks,
Christian
- roger1955Dec 08, 2020ApprenticeThat’s what I figured. I’ll let you know when I do. Right now, my home network is running strong.
Hi roger1955,
Sounds good. Please feel free to provide me with further updates.
Regards,Christian
