loiler
Nov 02, 2020Initiate
Cannot get 2nd set of nighthawk satellites to connect to first set
Hello, I am hoping I am posting to a Nighthawk community support. I purchased 2 - Mesh Wifi 6 systems from Costco (big box store). The package came each with 1 router and two satellites. I want to ...
- Nov 06, 2020
HI Loiler,
For the second package, in order for all 3 units to work, you will need to set the router in access point mode. Otherwise, you may use 1 package and sync it with the other 2 satellites from the second package. If you need any assistance, you may also contact our support team as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/default.aspx
Christian
Christian_R
Nov 06, 2020NETGEAR Employee Retired
HI Loiler,
Christian
