majd0910
May 02, 2020Tutor
Cannot get WiFi to show up!
Hello! Hope you are all well and safe. So, I have a AC2300 Nighthawk Router and I am having trouble activating the WiFi. Everything is connected and it says that Internet is connected as well, bu...
michaelkenward
May 03, 2020Guru - Experienced User
AC2300
majd0910 wrote:
Hello!
AC2300 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. I assume that we are talking about the R7000P in your footer.
majd0910 wrote:
I have Xfinity, I do not have bridge mode enabled because when I did, the internet light would shine orange (do not know what that entails).
So how do you connect to Xfinity?
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Apologies for the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
