rorzolek30
Oct 08, 2021Aspirant
Cannot reconnect to Wifi
I have an issue, where my router sometimes stops letting devices connect. All currenlty connected devices work, but if I leave the house and come back, our phones will not connect. On the phone it ju...
DarrenM
Oct 12, 2021Sr. NETGEAR Moderator
Have you tried to forget the network in your phone settings and then reconnect? it could have some old wifi settings saved causing the issue.
DarrenM
rorzolek30
Oct 12, 2021Aspirant
Yes. It actually happens with any device I try to connect. What is connected works, but trying to reconnect anything that had been previously or anything new just fails.
- DarrenMOct 13, 2021Sr. NETGEAR Moderator
Have you tried to change the wireless channel? https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
- rorzolek30Oct 13, 2021AspirantNo, I have not. I’ll give that a try and report back. Thanks!
