Xletron
May 03, 2021Aspirant
Cannot reset router password with SN (mesh MK60)
So, I have setup my wifi mesh system, all blue lights so it’s working. However, the default “admin” and “password” doesn’t work when trying to login to the router, and when I enter the serial number, ...
Xletron
For some reason the serial number doesn’t work. Anything on that?
May 04, 2021Guru - Experienced User
Again, password recovery requires more than just the serial number.
You might have to factory reset to get back to the default
default login: admin
default password: password
