sgau
Jan 13, 2022Tutor
cannot see one of the two external usb drive
I got 2 usb drives connected... one is usb 2.0 and other one is 3.0 both can be seen as available drives in "Advanced Setup->USB Settings->Available USB Devices" However, in windows I can only see...
- Jan 13, 2022
Not formatted for your laptop. It has to be in a proper format for the router.
What are the USB drive requirements for my Nighthawk router? | Answer | NETGEAR Support
sgau
Jan 13, 2022Tutor
yes, works fine when the drive is connected to laptop directly.
Jan 13, 2022Guru - Experienced User
- sgauJan 13, 2022Tutor
got it, thanks!
