DanBus
Sep 06, 2021Tutor
Cannot shut off Armor
I just got a Nighthawk AX6 6-Stream WiFi router. While setting it up, it took it upon itself to set up Armor. I have tried to take Armor off with no success. I even reset the router to factory settin...
- Sep 06, 2021
If you have the netgear on your mobile device, uninstall it. the Armor I have found is linked to the mobile app. If you must have the mobile app do not enable Armor after the reinstall.
robatl
Sep 06, 2021Star
- DanBusSep 06, 2021Tutor
I agree that the Netgear app seems buggy (needs repeated attempts at several of the steps to login, accept options, etc). After removing app, Armor still appears enabled in the router settings. Also, removing the app and reinstalled it 2 different times. Armor is activated by default.
I guess I can try once again to hard reset the router and set it up completely manually and see what happens?
Netgear ows me more than an hour's worth of time... ridicuous
Thank you for the good advice. I deleted the app from my phone, and then did a factory reset of the router. I set up the router manually using http://192.168.1.1 Under A Security status in now says "not activated". I shall now keep the app off of my phone.
Thank you again.
