xxtensazenxx
Jan 21, 2022Guide
Cannot upload files
Router Info: Model - AX12 RAX120V2 Firmware Version - V1.2.3.28 PC Info: OS - Windows 11 home Version - 10.0.22000 Build 22000 I've been running a server on my home internet for year...
Razor512
Jan 24, 2022Prodigy
For your sftp server, are you able to confirm if the port forward is working properly?
https://www.grc.com/default.htm
If you get a chance, head to GRC and then go to Services> Shields Up> Proceed
After that, have it probe the port that the server is using. Often it will be port 22, but some users may change it.
If it shows "stealth" then it means that nothing responded on that port, even if your router responds to general pings.
