ianiver9
Jul 23, 2020Aspirant
Cannot use web interface (400 Bad Request)
Hello. I have a R9000 Nighthawk X10 wifi router. I recently wantet to login to the web interface to make some changes. To my suprise, instead of the normal web logon screen, I get an a page saying th...
Jul 23, 2020Guru - Experienced User
You can still use the web interface. I still do. Its my preferred why of managing my router.
Usually you only see that notice if you're reinstalling/setting up the router for the first time.
maybe your device was reset somehow?
Have you tried a different pc and/or browser?
ianiver9
I have tried Windows, Linux, and MacOS, and I have tried different browsers. I always get the same page and the same error. It makes me think that there is something that the firmware update has broken. It is very frustrating.
- plemansJul 23, 2020Guru - Experienced User
Does it work through the app?
What are the led's on it doing?
the fact that it went to that page makes me think its already been reset (maybe unintional or from a power surge/failure)
- ianiver9Jul 23, 2020Aspirant
Yes, it is a reality that I will probably have to accept.
I will go the app route - begrudgingly - if I cannot get anywhere with the web interface.
It looks innevitable! :(
If you can take a backup (or have one) a reset might work so you don't have to use the app. I'm not a fan of the app so I'd be in the boat of doing a full reset so I wouldn't have to use it.
