ianiver9
Jul 23, 2020Aspirant
Cannot use web interface (400 Bad Request)
Hello. I have a R9000 Nighthawk X10 wifi router. I recently wantet to login to the web interface to make some changes. To my suprise, instead of the normal web logon screen, I get an a page saying th...
Jul 23, 2020Guru - Experienced User
Does it work through the app?
What are the led's on it doing?
the fact that it went to that page makes me think its already been reset (maybe unintional or from a power surge/failure)
ianiver9
Yes, it is a reality that I will probably have to accept.
I will go the app route - begrudgingly - if I cannot get anywhere with the web interface.
It looks innevitable! :(
- plemansJul 23, 2020Guru - Experienced User
If you can take a backup (or have one) a reset might work so you don't have to use the app. I'm not a fan of the app so I'd be in the boat of doing a full reset so I wouldn't have to use it.
