Tod63456
Jan 10, 2025Aspirant
Cannot wirelessly connect HP LaserJet 200
HP LaserJet 200 color M251nw . Is more than 10 years old but works well except for the following. Can connect with Ethernet cable. Cannot connect WiFi. Was able to WiFi with old router. Print...
Kitsap
Jan 10, 2025Master
Make sure you Wi-Fi password has no spaces or special characters.
- michaelkenwardJan 11, 2025Guru - Experienced User
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
Just another user with time on their hands.
