spyderz343's avatar
spyderz343
cant change trusted devices
I cant seem to change the trusted devices for multifactor authentication.
In the android app:
I have enabled and disabled to try to remove them
I have logged out and logged back in
Website:
I have tried through the website but I dont see a 2 factory authentication under login, in settings
I have seen other people post similar issues.
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hi spyderz343,
      Glad you got it figured out!
      Christian
    • mlenox's avatar
      mlenox
      Figured it out but didn't post a solution. I have same problem. Need to change trusted device to my new cell phone/number.
