DunePilot
Apr 21, 2019Aspirant
Can't check Enable QoS box on RAX80 Web UI
Setup is 1G xfinity service, Netgear CM1150V modem, Netgear RAX80 Router, Router on 1.0.1.56 Firmware.
I'm having random 5 second lagspikes/packet loss in games and want to enable QoS. In th...
DunePilot
Apr 22, 2019Aspirant
If you aggregate the lines for 2GB then it turns off QoS. Surely that is not working as intended. Rolled back the firmware while on the phone with Tech Support after letting them log the issue. I still couldn't enable QoS after firmware rollback, went back to latest firmware and then factory reset. Was able to turn QoS on, but aggregating the two ports (WAN aggregation in settings) turns QoS off and makes the QoS button unclickable.
schumaku
Apr 23, 2019Guru - Experienced User
Hard to say - in general (Netgrar's) QoS does not make any sense on Internet connections with these bandwidth, it will create an impact on the performance. Potentially - and now I'm on a wild guess - the embedded dedicated data stream processor where this QoS is run can't deal with that bandwidth (or it was simply not easy enough to redirect the [most likely again Linux bonding] software aggregation port to it).
