iaskenazi
May 31, 2019Aspirant
Can't configure AX40 as AP mode
I have spent countless hours trying to configure a new RAX40 as AP mode. I also have a Netgear 7800 and I didnt have any problem doing the same thing. I dont know if my unit is defective. Do you ha...
michaelkenward
Jun 01, 2019Guru - Experienced User
What are you doing and where does it go wrong?
The best way to put a router into AP mode is as a standalone operation. Connect the RAX40 to a PC and nothing else. Set it up in AP mode and then add it to the rest of the network.
And remember to start everything in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on the AP
- Turn on computers and rest of network.
iaskenazi
Jun 01, 2019Aspirant
I am probably doing some things wrong. ( I am not a network e pert at all but I was doing what a guy that does know a lot told me).
I have a Cisco Linksys router that assigned the ip to the network and 2 NETGEAR 7800 routers configured as access points.i will tell what I am doing.:
1. Connect the new AX40 to the switch via the yellow port.
2. Reset the ax40. (After trying unsuccessfully to make it work).
3. Once it turned on I connected to the Netgear31 via wifi (the new router default name).
4. The lights turn all green but it doesn’t have internet.
5. I type router login.net and start accessing the router config. (Create admin password, register etc)
6. after doing all that suddenly it has internet.
7. I go to advanced settings: wireless ap, turn on and apply. ( I have tried with and without fixed ip)
8. Once applied the laptop connects to my regular network while the new router is updating the config.
9, I ccnnect to the new network (didn’t change name at all) and it doesn’t have internet. Lights on the router are green.
10. I tried also the same but connecting to the black port instead of the yellow.
