iaskenazi
May 31, 2019Aspirant
Can't configure AX40 as AP mode
I have spent countless hours trying to configure a new RAX40 as AP mode. I also have a Netgear 7800 and I didnt have any problem doing the same thing. I dont know if my unit is defective. Do you ha...
iaskenazi
Jun 01, 2019Aspirant
I have an old lap with Ethernet port.
When you say connect the RAX to a pc and nothing more should the lap be connected to rax via cable or wifi.
I tried also to do it with that computer but I kept connected the rax to the network via yellow port and connected the lap to one of the black ports. I needed to connect via WiFi anyway so it didn’t do any difference
schumaku
Jun 01, 2019Guru - Experienced User
Just a network cable connection to the existing network, and e.g. a wireless device accessing the AX40 wireless for example.
When using the AX40 alone, the system connected (via wireless or the old PC by network cable on a LAN port) should not receive an IP address, as the DHCP server should be disabled.
