Heywoodjablome6
Jul 04, 2021Follower
Cant connect my Android phone to the Netgear Wifi extender AX1800.It keeps saying "cant authenticate
Jul 04, 2021Guru - Experienced User
What actual extender do you have? (ax1800 is a speed)
What router are you connecting it to?
What method of setup did you use? (wps or the installation assistant)
