lo53n
Sep 06, 2022Aspirant
Can't connect to AX1800 over ethernet despite cable connection
Hello, recently I got AX1800. I managed to configure it over WiFi with more or less problems, however I am not able to connect to it via ethernet cable. The LED on router for connection is lit, h...
Sep 06, 2022Guru - Experienced User
1. what router do you have? AX1800 is a speed
2. what modem/gateway did you connect it to?
3. You're still able to access it via wifi and use it? Just not via ethernet?
lo53n
1. Ah, AX1800 is shown is such big letter on the box I thought it was model. It's RAX20 (RAX20-100PES as producer code).
2. I'm connecting straight to my ISP, on my side there is no modem or anything like that, just router. @Edit as per gateway, I'm assuming network gateways? I'm using the ones automatically provided by ISP, as they were always working for me.
3. Yes, WiFi is working fine. I can connect to router via WiFi with no problem, both on 2.4GHz and 5GHz networks. It's just I'm not able to connect over ethernet cable as if PC isn't able to recognize it is sitting in LAN.
- plemansSep 06, 2022Guru - Experienced User
Correct, your gateway from the isp. they must have something even if its just an ONT.
Did you try simple factory resetting and starting over? Sometimes the fastest solution.
- lo53nSep 06, 2022Aspirant
I've tried couple of times, but the best result was my PC's ethernet connection deciding to take DHCP address (192.168.1.2, which is reserved by router) in network named "Netgear 5G", and then after a while switching to "Unidentified Network" with no IP set.
what ont/gateway is it from the isp?
