Mattsevi
Dec 08, 2024Aspirant
Cant connect to internet with new router
Cant connect with my new router i have nbn also changed the mac address and vlan 2 priority 0
michaelkenward
Dec 09, 2024Guru - Experienced User
What is that new router?
Is this the Australian NBN network?
What connects to the router to the Internet?
Just another user with time on their hands.
Mattsevi
Dec 09, 2024Aspirant
Hi
Its an Axe300
Yes australia
Nbn box connects to my new router
Its an Axe300
Yes australia
- michaelkenwardDec 09, 2024Guru - Experienced User
Mattsevi wrote:
Nbn box connects to my new routerWhat is that NBN box?
What sort of Internet do you have?
NBN just means Australian Internet. It comes in different types. Cable? DSL? Optical? They all have different ways to connect.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
- MattseviDec 09, 2024AspirantFttp cable i think has a UNI-D port i put an ethernet cable there to my nighthawk lan internet port.
I spoke to an tech and he said i needed my pppoe user name which i now have, i put it in put that didnt end up solving my issue- michaelkenwardDec 09, 2024Guru - Experienced User
Mattsevi wrote:
Fttp cable i think has a UNI-D port i put an ethernet cable there to my nighthawk lan internet port.Again, the Ozzie idea of FTTP is not universal. But this usually delivers the Internet through an optical network termination (ONT). That then has a connection that you can run to the WAN (Internet) port on the router.
You say you have an Axe300. That isn't a Netgear router model. Look at the label on the bottom of the thing.
Do you mean RAXE300?
I spoke to an tech and he said i needed my pppoe user name which i now have, i put it in put that didnt end up solving my issueYou should reset the router and then try the manual setup. Again, see what the manual says.
The pppoe username may just be a part of the details you need. That is down to how the ISP operates.
