auscyber
Oct 17, 2020Follower
Cant connect to Nighthawk MK63 mesh wirelessly on any device
I have reset my router three times to factory settings. restarted it even more. and i cant connect any devices to it wirelessly. over ethernet its fine and i have internet access. just no wifi. it jus...
Christian_R
Oct 22, 2020NETGEAR Employee Retired
Hello auscyber,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
