LConaway59
Feb 11, 2021Tutor
Can't connect to RAX10 after Windows 10 Upgrade
I upgraded my laptop from Windows 7 to Windows 10 last week and have not been able to access the internet through wireless. I can access via Ethernet wire. Other devices in the home can access the RA...
Feb 12, 2021Guru - Experienced User
What wireless chipset are you using in the computer?
What driver version is on the wireless chipset?
LConaway59
Feb 12, 2021Tutor
Wireless chipset: Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC
Driver Version: 2013.12.331.2016
- schumakuFeb 12, 2021Guru - Experienced User
- LConaway59Feb 15, 2021Tutor
Appreciate the advice. Driver was not compatible with my Toshiba Satellite L775D-S7305 system.
