smitch9's avatar
smitch9
Can't connect to RAX20 when setting WPA3
I recently installed an RAX20 and noticed that it had WPA3 security after setting it up with the default WPA2.  When I switched it to WPA3 with the same password as used for WPA2, I could not connect...
