gmgrey
Jul 26, 2023Aspirant
Can't connect to VPN Service
I'm trying to set up a local VPN on my new RAX50 router, but I can't seem to connect to it. I've enabled the VPN Service from the router settings, installed OpenVPN to the client computer I want to c...
- Jul 28, 2023
I see. I figured there would be some sort of problem with connecting to the local VPN while already connected to the VPN, I just couldn't think of any other solution. However, I forgot I had the ability to use USB tethering with my phone to connect to the internet on a computer. As far as I know, there shouldn't be any issues in doing that.
To answer your question about Mullvad, it was running on the laptop I was using to connect to the local VPN.
While connected to the mobile hotspot I was able to connect to the VPN successfully, both with and without the DDNS server. I made sure I had WiFi turned off just to be sure I'm not accidentally connected to my local network that way. I'm not sure why I wasn't able to connect while in a different network before, maybe it has something to do with it being a university network?
I won't have an opportunity to physically move to another network until early next week, but as soon as I can I'll test this again at a public library. I'll reach back out if I can't connect to the local VPN there, if I can then I'll set this post as the solution. If I end up doing that, then the solution was that connecting to the local VPN while still connected to your local network will always fail.
Kitsap
Jul 26, 2023Master
gmgrey wrote:I'm trying to set up a local VPN on my new RAX50 router, but I can't seem to connect to it. I've enabled the VPN Service from the router settings, installed OpenVPN to the client computer I want to connect to the VPN with, downloaded the configuration files from the host computer, sent them to the client computer, and put them in the C:\Program Files\OpenVPN\config folder. (I know I should set up a DDNS server so I don't have to download new config files whenever my IP Address changes, but I want to get the VPN working without one first.) When I open OpenVPN, it gets stuck at MANAGEMENT: >STATE:1690405121.WAIT for 60 seconds before giving the error message TLS Error: key negotiation failed to occur within 60 seconds. Both the host and client computers are connected to the internet. From all of the guides I've seen, I have done everything exactly as I should have. Is there something I'm missing?
Once you have installed the Open VPN client software on a test computer, you cannot test the connection with the computer connected to the internet via the router where you have the VPN server enabled. You must go to a friend’s house, restaurant, etc.
On the test computer where you installed the Open VPN client software, make sure you renamed the local area connection to NETGEAR-VPN.
To get started, In the router configuration, set the TUN mode and TAP mode service type to TCP. Also set the VPN connection to access all sites on the Internet & Home Network.
Any time you make a change to the router configuration, you must generate a new set of configuration files for the client computer.
You should be OK with your decision on the DDNS until you are happy with the configuration.
gmgrey
Jul 27, 2023Aspirant
I see, probably should have figured it wouldn't work if I was already connected to my local network.
I went to a different network and tried to connect to the local VPN there, and this time I got different results. First, it got stuck at MANAGEMENT: >STATE:1690477355,TCP_CONNECT for over a minute, and then it would say that it couldn't connect due to an unknown error. I did make sure the local area connection labelled TAP-Windows Adapter was renamed to NETGEAR-VPN, and I also changed the VPN settings as you suggested before trying to connect and then generated the configuration files that I used to try to connect. I even set up a DDNS server previously and set my PC to update the IP address, and while I was connected to the external network I edited client1.ovpn and changed the IP address in the line that stars with "remote" to the URL of the DDNS server and got the same result when I tried connecting.
This might be unrelated, but I'm also having issues with the router's Wifi. The router settings say it's been turned off, and when I go to turn it on it says I have to press the Wifi On/Off button on the router. I do that, and it still won't broadcast the SSIDs and now I can't connect to the router settings anymore, either through routerlogin.net or 192.168.1.1, until I restart the router. The only thing I changed is the VPN settings.
