Squawkboxx
May 03, 2020Aspirant
Can't Decide which to purchase: Netgear Wifi 6 Duel Band (RAX120) or Tri Band Router (RAX200)
II know I want to purchase one of the two routers. I'm not sure if a tri-band WIFI 6 router would be overkill. I have a total of 30-35 devices. These devices include three iPhones with WIFI 6 capabil...
Squawkboxx
May 04, 2020Aspirant
My house is a one level house 1,518sq feet. Although, we will be finishing our basement in the next year. Thank you for the reply!
May 04, 2020Guru - Experienced User
so finished it'll be just short of 3200?
Mines right about that but its a tri-level. I run an AP on each level. Much better coverage than just the RAX
- SquawkboxxMay 04, 2020Aspirant
Sorry...I should have been more detailed with my houses' square footage. That is the total square footage included the basement.
- plemansMay 04, 2020Guru - Experienced User
Then 1 device should cover it fine if its wood/sheetrock construction.
- NordicBastrdMay 04, 2020Apprentice
I would suggest neither. If you look through these forums there is nothing but issues with the RAX120 and 200. My RAX 120 is mostly a $400 performance downgrade and stability issues all over the place compared to my 4 year old ASUS router.
- plemansMay 04, 2020Guru - Experienced UserHuh. I must have gotten a defective one because mine works fine?
You realize that this is the forums where people come with problems? The ones without issues don't post for help on here.
