Squawkboxx
May 03, 2020Aspirant
Can't Decide which to purchase: Netgear Wifi 6 Duel Band (RAX120) or Tri Band Router (RAX200)
II know I want to purchase one of the two routers. I'm not sure if a tri-band WIFI 6 router would be overkill. I have a total of 30-35 devices. These devices include three iPhones with WIFI 6 capabil...
Newfiedrool
May 05, 2020Virtuoso
plemans wrote:
Huh. I must have gotten a defective one because mine works fine?
You realize that this is the forums where people come with problems? The ones without issues don't post for help on here.
I'm with you, I purchased the RAX120 and then purchased another for a family member and both work fine.
very good WiFi coverage and work as intended with the latest firmware.
If I'm honest the QoS needs some work still but apart from that no issues.
NordicBastrd
May 05, 2020Apprentice
Sure it works fine as long as you don't want to use 802.11 ax or you don't care if it is slower than a 5 year old router.
