Melbourne_Sam
Aug 22, 2021Aspirant
Can't Disable DLNA
Recently Purchased RAX20 and updated to Firmware Version V1.0.3.96_2.0.59. I want to disable/switch off the DLNA but cannot get it to save the setting. The tick box can be deselected but clicking...
DarrenM
Aug 23, 2021Sr. NETGEAR Moderator
Have you tried to use another web browser? or make sure a pop up blocker is not causing the issue?
DarrenM
- Melbourne_SamAug 23, 2021Aspirant
DarrenM wrote:Have you tried to use another web browser? or make sure a pop up blocker is not causing the issue?
DarrenM
I have tried using Chrome, Internet Explorer, Edge on three different machines and the result is the same. Clicking the "Apply" button does nothing.
- DarrenMAug 26, 2021Sr. NETGEAR Moderator
I will report this bug the last thing you could try is to revert the firmware and see if it allows you to disable and then update the firmware.
DarrenM
