Melbourne_Sam
Aug 22, 2021Aspirant
Can't Disable DLNA
Recently Purchased RAX20 and updated to Firmware Version V1.0.3.96_2.0.59. I want to disable/switch off the DLNA but cannot get it to save the setting. The tick box can be deselected but clicking...
Melbourne_Sam
Aug 23, 2021Aspirant
DarrenM wrote:Have you tried to use another web browser? or make sure a pop up blocker is not causing the issue?
DarrenM
I have tried using Chrome, Internet Explorer, Edge on three different machines and the result is the same. Clicking the "Apply" button does nothing.
DarrenM
Aug 26, 2021Sr. NETGEAR Moderator
I will report this bug the last thing you could try is to revert the firmware and see if it allows you to disable and then update the firmware.
DarrenM
