sleekone
May 03, 2020Tutor
Can't get Gigibit speeds from Nighthawk Routers (RAX45, R6400)
I have the RAX45 | Nighthawk (AX4300) but it wasn't on the list to select, so I'll pick the RAX40 https://www.netgear.com/support/product/rax45.aspx https://www.netgear.com/home/products/networking...
- May 09, 2020
Hey Christian,
thanks for the reply, I ended up doing a factory reset on the router and that fixed my issue. I am now getting full speeds. So far its been working great since yesterday.
Christian_R
May 12, 2020NETGEAR Employee Retired
Hi mando41,
Happy to hear!
Best,
Christian
