Dan_0's avatar
Dan_0
Can't Login to my Account - No matter what I do!
I can't Login to my Account - No matter what I do.
Everything seems to go fine (resetting password,  etc.)
And at the end, when I think I'm about to get in, it comes back with the message...
"Something went wrong.  Try again"
  • michaelkenward's avatar
    michaelkenward
    Login to what and with what?
    Netgear allows various "Accounts". MyNetgear. for example, isn't the same as this place, AnyWhere Access or the wifi. And apps are not the same as browsers.
    Take us through the steps that get you to that dead end.
    Disclaimer: Just another user with time on their hands.
    • Dan_0's avatar
      Dan_0
      Thanks for the reply.
      I'm trying to login to my RAX43V2 with my Google Chrome web browser.  I can login with the Nighthawk App but it seems limited and it does not show ip addresses for my devices.
      When I try to use the browser, I put in my username and password and then it takes me to a screen that says I need an account but if I already have an account, click here...
      So then I put in my username and password and it tells me something went wrong.
      I try to reset the password, everything seems to go normally,  I do the 2-step verification and it tells me something went wrong.
      So then I tried to use the serial number procedure.  That seems to work until the very last step and it tells me something went wrong.
      I noticed the Anywhere Access and I have tried it both ways.
      Thanks again for your reply.
