StupidInsanity
Feb 09, 2024Guide
Can't login to RAX43v2 to change settings
Any time I try to login to my router, a RAX43v2, I get prompted for a username and password as expected. However, as soon as I enter my username and password I get redirected to this stupid, unhelpf...
- Feb 09, 2024
Looks like you're not the only one having issues .
StupidInsanity
Feb 09, 2024Guide
So basically, I have to factory reset and redo my entire network setup. Awesome.
michaelkenward
Feb 09, 2024Guru - Experienced User
Unless you can find a way in, afraid so.
Do you have a backup of your current configuration?
It isn't always a good idea to reload that, but you lose nothing by trying it.
Reload it and see what happens. If all is well, breathe a sigh of relief. If not, pour yourself a stuff drink/cup of coffee and get to work.
- schumakuFeb 09, 2024Guru - Experienced User
...or the day Netgear does provide a firmware built without this fancy dual-redirect, and this will be loaded unattended - then yes.
