StupidInsanity
Feb 09, 2024Guide
Can't login to RAX43v2 to change settings
Any time I try to login to my router, a RAX43v2, I get prompted for a username and password as expected. However, as soon as I enter my username and password I get redirected to this stupid, unhelpf...
- Feb 09, 2024
Looks like you're not the only one having issues .
StupidInsanity
Feb 09, 2024Guide
The "solution" was a factory reset.
My last backup was from October. Guess I'll be doing weekly backups of my config from now on. Thanks Netgear.
