Kingstevemzz
Dec 18, 2019Aspirant
Cant open my port on my Nighthawk X6 AC 3200 Tri-band R8000
Hello, i have been trying to setup a minecraft server for a while now and ive finally managed to get my servre working. I can sucessfully join my own server locally but when my friends try to join it doesn't work. After doing a little bit of research i found out that my port that my server uses is closed. Anything technical beyond creating a port is too much for me to understand, i need help trying to open my port through any means possible, and try to be simplistic as i do not really know much about routers and electronics alike. Any help is appreciated!
My port is a default 25565 which minecraft uses and the server and port are both located on my main computer.
If screenshots or more relevant information is needed, please ask for them!
Check the various discussions on the same issue.
Search - NETGEAR Communities – minecraft
I doubt if there is a lot new to be added.
- KingstevemzzAspirant
I was hoping for a more personal solution as i cannot find other solutions to the problem i have concerning my own router and setup. i just need a simple walkthrough to open my port
