BeeBeeMan
Nov 08, 2023Aspirant
Can't raise a support ticket or RMA for in-warranty
I'm within Hardware Warranty Support and Netgear do absolutely everything they can to make the process impossible to do unless you purchase Gear head support. I was told that the RMA needs to be appr...
Nov 08, 2023Guru - Experienced User
Do you open a support ticket thru here?
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
BeeBeeMan
Hi FURRYe38,
I wasn't able to open a support ticket through the portal due to only having warranty support. I called through and had to convince an agent to open an RMA them confirming I have warranty support.
I have a support case now but the Agent advised the RAX80 isn't on the RMA form for them and they need to speak to the warehouse.
Can a Netgear rep please advise why the RAX80 wouldn't be on the RMA form?
