BeeBeeMan
Nov 08, 2023Aspirant
Can't raise a support ticket or RMA for in-warranty
I'm within Hardware Warranty Support and Netgear do absolutely everything they can to make the process impossible to do unless you purchase Gear head support. I was told that the RMA needs to be appr...
Nov 08, 2023Guru - Experienced User
Do you open a support ticket thru here?
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
DarrenM
Nov 09, 2023Sr. NETGEAR Moderator
I have sent you a PM BeeBeeMan
DarrenM
