MAD5
Nov 29, 2022Tutor
Can't see 6 ghz on RAXE500
I try with my S22 Ultra and only connect to WIFI 6 but not 6E. It doesn't appear on the list. Only 2,4 and 5 ghz. Also try with my notebook Lenovo which has Intel AX210 with windows 11 and lastest In...
Razor512
Nov 08, 2023Prodigy
Sadly the latest seems to be only V1.0.12.96 https://kb.netgear.com/000065500/RAXE500-Firmware-Version-1-0-12-96
MAD5
Dec 12, 2023Tutor
I installed today the new firmware 1.2.13.100 and still no 6 ghz working. I was told that they will include this feature in the next firmware upgrade, but still nothing shows on the notes and yet, no 6 ghz working. Any idea when 6 ghz will work in Argentina?
- FURRYe38Dec 12, 2023Guru - Experienced User
Something to contact NG support about as this is beyond forum help.
Good Luck.
- MAD5Dec 12, 2023Tutor
How do I contact support if it show it is only for 3 months, and been waiting for this update since february.
Ok, I got someone on the phone and confirm me that need to wait anorther 4 or 5 months to get a new firmware which will solve this issue.
Thanks for letting us know.
- fedems1982Apr 08, 2024Aspirant
Hi guys,
I have exactly same problem as MAD , same router model.. and living also in Argentina. Is there any update regarding the firmware update? DarrenM
- FURRYe38Apr 09, 2024Guru - Experienced User
Something to contact NG support about.
Good Luck.
fedems1982 wrote:
Hi guys,
- MAD5Apr 09, 2024Tutor
I got finally working, at least in part with my S22 Ultra, I can see it now and connect, but from notebook it never appears. So I guess still need to wait they get the new firmware to get fully supported.
- fedems1982Apr 09, 2024AspirantNice, please share the details , what steps/procedure do you follow to have it working?
- michaelkenwardApr 09, 2024Guru - Experienced User
The laptop supports 6 GHz? It has the drivers latest for the wifi?
If you have got it to work on the S22 Ultra that points the finger at the laptop. If your wifi client can't see the router's wifi, there not much that Netgear can do about that.
- mayo73Apr 12, 2024Star
On your notebook , update the wifi drivers . Here is the link . May help.
