Russje's avatar
Russje
Tutor
Oct 21, 2021
Can't see 6E wifi (RAXE500)
Hello,   I recently purchase this router and it is working great.  However, I just built a Gigabyte Aorus Master X570s that support Wifi 6E.  However, I can't even see the 6E SSID for this network....
  • Russje's avatar
    Russje
    Oct 21, 2021
    It was a fresh W10 install with the new MB.  However, I went ahead and did an in-place upgrade to Windows 11 and it found it with no problems.  So either I will stick with W11 or revert back to W10 for now and upgrade later.
    At least I know it does work as I have no other devices with 6E...four iPhones 13 and a new MS Surface Studio laptop and not one 6E device.  lol
    Thanks all for your feedback and help.
