yegloats
Oct 04, 2019Aspirant
Can't see network on one PC
This past week I switched from a Netgear R8000 to the new RAX200. When setting up the new router it gave me the option to keep my previous SSID and password. I did that and had success completing the...
- Oct 06, 2019
yegloats wrote:I'm not exactly sure what you mean by "This is an AX router". I'll guess that it means that I can set the router to combine the three channels so that it looks like one and the router decides which channel to use for the connection. I did turn that function off and did not have any change in what the PC identified as available networks. I don't have any new devices that have AX (WiFi6) capability. I do have another Windows laptop that connected with no problem.
>>> go to BASIC--> wireless page and uncheck "enable AX ..."
Oct 04, 2019Guru - Experienced User
I guess I'm a little confused.
Your pc can't see the wireless network?
Or its connected to the network (aka internet working) but can't see other devices on the network?
How are you connecting to it? wireless/wired and what specific adapter is it
- myerswOct 04, 2019Master
This is an AX router. Some devices, especially PC's do not like AX for some reason and will not connect. Try turning AX off and see. Then you can decide if AX is even needed. Any AX clients?
- yegloatsOct 04, 2019Aspirant
- AltsaiOct 06, 2019NETGEAR Expert
The PC can't see the wireless network. It sees our neighbors networks butr not ours. Not sure about the adapter. It is an Asus laptop. that previously connected to the network when I used the previous router.
