emerywang
May 07, 2020Aspirant
Can't see router from wired PC, RAX15
Hi. I have an AX1800/RAX15 router, just bought it last week. It's not listed in the models dropdown menu so couldn't select the model. Anyway, it works fine and I can access it thru router.com on...
May 07, 2020Guru - Experienced User
1. what modem are you using?
2. what firmware is on the RAX?
3. What switch are you using?
4. Are you in a double nat? it can cause issues with the routerlogin connect as well as possible the printers as well. https://kb.netgear.com/30186/What-is-Double-NAT
5. do you have your computer set to "private" connection in windows? Or public? it might not "find" the printers if its on public.
- emerywangMay 07, 2020Aspirant
Thanks Plemans. I figured out the problem. Our IT guy recently set up a VPN for us to connect to the office from home, and it can't see the router when the VPN is on. Disabling the VPN fixed it.
I appreciate the help.
-Emery
