DenisB
Nov 14, 2021Aspirant
Can't use anymore the access control directly from my router RAX50
Hi, I have updated recently the Nighthawk android app on my phone and also the firmware on my RAX50. Firmware version is V1.0.4.100_2.0.64. The problem is that I can't anymore manage the co...
Nov 14, 2021Guru - Experienced User
Downgrade FW back to what had been working?
NG seems to be moving away from router web page based controls to the Nighthawk app and Smart Parental Controls there.
DenisB
Hi, thanks for the reply,
Reverting to the previous version didn't do anything. I already tried to go back 3 versions behind without success.
From what version the access control through mobile app have been enabled?
Thanks
- DenisBNov 16, 2021Aspirant
Hi,
I finally found the version that allow the use of access control directly from the router interface.
I've rolled-back to V1.0.2.72_2.0.45 and everything is fine now.
Denis
