OldBob's avatar
OldBob
Luminary
Jan 08, 2020
cat 5e wire that came with Nighthawk router
My new  Netgear router came with a VERY thin black wire that is labeled Cat 5e.  All the videos and my current wire from the modem to the router is a thick yellow wire labeled also Cat 5e.  Is 5E  5E...
  • OldBob's avatar
    OldBob
    Jan 08, 2020
    Thank you..can I use the thinner one that was in the Nighthawk package to connect my laptop to the router when doing firmware updates to get the wired connection needed?
