Jdkiskamp
Sep 23, 2021Follower
CAX 30 no lights
About 40 minutes ago, my router modem (Nighthawk CAX30 AX2700) went completely unresponsive. No lights, no response to buttons (including reset) and no response to an unplug-plug in
Sep 24, 2021Guru - Experienced User
Have you checked the power supply?
I'd start there.
I'd also open a support case with netgear.
Click on "mynetgear" at the top. register an account and the device. From there you can check warranty status/support status.
