myslad
Aug 02, 2021Aspirant
CAX30 — Nighthawk AX6 6-Stream WiFi 6 Cable Modem Router
Whats the maximum dowload speed that we can expect. I have xfinity 1.2 gig connection I get only 200 MBps, with wired connection? Any settings need to be tuned?
Aug 03, 2021Guru - Experienced User
Its a docsis 3.1 device. It should support gig+ speeds.
Do you have a screen snip of the cable connctions page and the event logs?
That lets us check your connection
