mfhawn's avatar
mfhawn
CAX30 - wireless speed
I just got a new laptop with an Intel Wi-Fi 6E AX211 160MHz wireless card.  I cannot get beyond 1201 Mbps, which is the same speed my previous laptop hit.        Is there something I could have set...
  • StephenB's avatar
    Apr 25, 2026
    This is expected.
    The CAX30 has supports 3x3 with 80 mhz channels, which gives the max link speed of ~1800 mbps.  Note the 3x3 is the number of antennas (three transmit, three receive).
    The AX211 is 2x2 (two transmit antennas, two receive).  If the CAX30 supported 160 mhz channels, you'd get a max link speed of 2400 mbps.  But since the CAX30 is limited to 80 mhz channels, the max link speed is half that (which is what you are seeing).
