Autumn47
Sep 15, 2021Aspirant
CAX30 AX2700 big drop in speed
I have a 1gbps internet plan for home and have noticed consistent slow speeds. I decided to call the cable company's technican and his test results were as below 1, Co-axial cable to his hand held t...
Sep 15, 2021Guru - Experienced User
did you try a simple factory reset/reinstall of the router?
