Autumn47
Sep 15, 2021Aspirant
CAX30 AX2700 big drop in speed
I have a 1gbps internet plan for home and have noticed consistent slow speeds. I decided to call the cable company's technican and his test results were as below 1, Co-axial cable to his hand held t...
Autumn47
Yes I did the reset and no change in the speed. Also tried playing around with the channels..to no avail.
Sep 15, 2021Guru - Experienced User
what speeds do you get?
Not the tech
- Autumn47Sep 15, 2021Aspirant2.4 ~150mbps
5.0 197mbps
Wired ~250 mbps- plemansSep 15, 2021Guru - Experienced User
contact xfinity and have them re-provision it. i've seen them send the wrong provisioning file to a modem before.
- Autumn47Sep 15, 2021AspirantI have optimum. The tech came today and tested the connection. A direct coaxial to his testing device gave a speed of 988mbps. Coaxial to Netgear to his testing device gave a speed of 250+ mbps
